Okuma Alarm-B 2460 Change timing G13/G14
On the models with facing turrets models, G13 and G14 mode is changed while in incremental programming mode, tool nose radius compensation mode, LAP mode, and constant cutting speed mode.
1->Changed in incremental programming mode.
2->Changed in tool nose radius compensation mode.
3->Changed in LAP mode.
4->Changed in constant cutting speed mode.
5->Changed in buffer reading for required angle chamfering operation
G13, G14 command
Program Example:
->Code 1 appears. G13 G00 X100 Z100 G91 X-20 Z20 G14 G00 X50 Z50 : M02 ->Code 5 appears. *Coordinate values are not determined until the next sequence is read. N010 G13 N020 M03 S1000 N030 G00 X20 Z120 N040 G75 G01 X60 L6 F0.2 N050 G75 Z90 L5* N060 G14 N070 G00 X100 Z100 : M02 ->Code 4 appears. G13 G96 S100 G00 X100 G14 G00 X20 Z20 M02
For alarms of code 1, 2, 3 or 4, change the G13 and G14 modes after canceling the operation mode first.
For the alarm of code 5, change the G13 and G14 modes after designating the end point in the sequence following G75.
Related Specifications
Facing-turret specification
