Okuma Alarm-B 2462 Change timing G122/G123
In the machine with sub-spindle, the coordinate system change command G122 or G123 is designated while either A or B is in
G141 mode (sub-spindle coordinate system) or while the nose R compensation is carried out.
XX:Designated G code (in hexadecimal)
Programming error
Program Example:
G141
G123
Check and correct the program.
G123
G141
