Okuma Alarm-B 2480 G132/G133 command error
The floating zero point calculation error occurred in the conversion from (X, C) to CE during the cutter radius compensation mode (CE Z plane) or contour generation machining (G132, G133) on the side face.
XX:
bit0->Overflow in converting into integer
bit1->Exponential underflow
bit2->Exponential overflow
bit3->Calculation of root of a negative number
bit4->Division by 0
bit5->Angle overflow for SIN, COS, TAN and COT
