Okuma Alarm-B 2509 MULTI-MACHINING CYCLE Return point
There is an error in the designated return point of the multi-machining cycle (G118/M964/M965).
1->The G118 sequence has no X,Z command.
2->Multi-machining cycle command is ordered though M964 is effectived and required conditions as follows were not satisfied.
[G178,G179,G181-G184,G189,G296,G298]
(1)return point <= cutting start point
(1)return point >= cutting start point >
cutting target point
(2)actual point >= cutting start point >
[G297]
(1)return point < cutting target point
(1)return point > cutting target point >
cutting start point
(2)actual point > cutting target point >
cutting start point
3->When M964 was issued, the designated return point is not define.
4->M964/M965 and M136 is designated in the same block.
Faulty program
Check the designated return point
Related Specifications
Multi-machining model
