Okuma Alarm-B 2537 SLANT PROCESS MODE
The slant process mode IN/OUT command(G127/G126) was executed though the required conditions were not satisfied.
Or, a prohibited command was executed in the slant process mode.
XX
XX=1->G127 slant process mode ON command were performed by the condition which is not Y axis mode.
Or, Y axis mode OFF command(G136) was performed in slant process mode.
XX=2->In nose-R compensation, G127 slant process mode ON command were performed.
Or, nose-R compensation ON command(G41/G42) was performed in slant process mode.
XX=3->By the end of LAP cycle, G127 slant process mode ON command were performed.
Or, LAP command was performed in slant process mode.
XX=4->In slant process mode, G127 slant process mode ON command were performed.
XX=5->The slant process mode ON command(G127) were executed during coordinate conversion(by G137) of the coordinate convertible specification.
Or, coordinate conversion ON command(G137) of the coordinate convertible specification was performed in slant process mode.
XX=6->In compoud fixed cycle, the slant process mode ON/OFF command(G127/G126) were executed.
XX=7->In slant process mode, the axis movement command which does not correspond for slant process or a compound fixed cycle command was executed.
XX=8->In the slant process mode, spindle mode command (G140, G141, G142) was executed.
XX=11->When tool retraction interruption mode, command G127/G126 was ordered.
Programming error
Correct the program.
