Okuma Alarm-B 2545 MULTI-MACHINING CYCLE LD
Designated LD value is not: 0 < LD <= 99999.999LD: A depth of cut in deep hole synchronization tapObject
FFFFFFFF->LD<=LK("Pecking amount in tapping cycle" of an OPTIONAL PARAMETER(MULTIPLE MACHINING) is used when there is no LK value. )FFFFFFFE->A different processing pattern instruction was done at the synchronization tap cycle of a continuous block.
Others->Hexadecimal number of designated LD value
Faulty program (compound fixed cycle block)
Program Example 1:
G178 X40 Z80 C0 I46 F40 L30 LD=-10
<- It is outside the range.G178 X40 Z80 C0 I46 F40 L30 LD=0.001<- It is smaller than the parameter value.Program Example 2:G178 X50 Z50 F=100 K10 L20 <- There is no LD value.X70 Z30 LD=10 <- There is LD value.Measures to Take
Check the LD command in the compound fixed cycle block.
G178 X40 Z80 C0 I46 F40 L30 LD=10
Related Specifications
Multi-machining model
