Okuma Alarm-B 2589 Definition conditions
Among the commands for defining the off-center circle in the shape definition file(LSF file), the relation between D command value(diameter of off-center circle) and L command value(offset amount) does not satisfy the following condition:
L is larger than 0, and equal to or smaller than D/2.
Deviation value in hexadecimal
1)The L-command has a negative value.
2)The L-command value is larger than a half of D command value.
1)Enter a positive value for L command.
2)Specify the L-command with a value smaller than a half of D command value.
