Okuma Alarm-B 2602 SCHEDULE PROGRAM main program load
An error occurred when a main program was selected in schedule program.
XXXX
5200:An attempt to select a program during the execution of a main program.
5201:Main program file was not found.
5202:Main program name was not found.
5203:Subprogram name was not found.
5204:Subprogram name was not found after CALL
G and M code macro was not defined.
5209:The end of program code was not specified at the end of a file.
5210:Program stack overflow
5211:The program buffer size excluding the schedule program and library program was less than 32K byte.
5215:More the 158 characters contain in the one block
5230:The option is not permitted.
5231:Mismatch between the end of file and the end of record
5374:Program selection by DNC-DT failed because of faulty file name.The total characters of device name, path name, and file name exceeds 120.
5375:An alarm occurred during program selection by DNC-DT.
1.Main program selected by schedule program
