Okuma Alarm-B 2617 Zero setting condition
Zero offset data could not be changed due to the setting for the system variable.
X
X = 1 -> An attempt was made to change the Z-axis zero offset data at the sub spindle side although the W-axis was not positioned at the variable limit in the positive direction.
Corrective Action
Move the W-axis to the variable limit in the positive direction before changing the zero offset data.
