Okuma Alarm-B 2632 DNC-DT Program select
An alarm occurred during program selection by DNC-DT.
Index
YY: YY application error NO.
800000XX: XX communicative error NO.
FFFFFFFFF: NC programmes over of a letter of 1 line are edited
FFFFFFFFD: program buffer overflow
XX=6F: Buffer in TCP/IP driver is too small.
XX=72: Descriptor transferred to TCP/IP driver is faulty.
XX=73: Parameters transferred to TCP/IP driver is faulty.
XX=74: There is no empty port in the shared memory.
XX=75: DNC is not connected.
XX=7B: The abort command was ignored.
XX=7D: “ftp_ms_open” abnormal termination
XX=7E: “ftp_ms_close” abnormal termination
XX=7F: “ftp_ms_type” abnormal termination
XX=80: “ftp_ms_user” abnormal termination
XX=81: “ftp_ms_pass” abnormal termination
XX=82: “ftp_ms_acct” abnormal termination
XX=83: “ftp_ms_delete” abnormal termination
XX=84: “ftp_ms_fopen” abnormal termination
XX=85: “ftp_ms_fopen_uni” abnormal termination
XX=86: “ftp_ms_net_drecv_f” abnormal termination
XX=87: “ftp_ms_net_dsend_f” abnormal termination
XX=88: “ftp_ms_fclose” abnormal termination
XX=89: “ftp_ms_abort” abnormal termination
XX=8A: “ftp_ms_chdir” abnormal termination
XX=8B: “ftp_ms_mkdir” abnormal termination
XX=8C: “ftp_ms_rmdir” abnormal termination
XX=8D: “ftp_ms_pwd” abnormal termination
XX=8E: “ftp_ms_cdup” abnormal termination
XX=8F: “ftp_ms_dopen” abnormal termination
XX=90: “ftp_ms_dread” abnormal termination
XX=91: “ftp_ms_dclose” abnormal termination
XX=97: IP address abnormal
XX=98: No IP address
XX=99: Interruption by time out
XX=9A: Disconnection command from the remote host
XX=9B: Abnormal termination of initialization of OS (MORE) on TCP/IP board
XX=9C: Abnormal termination of initialization of packet driver or TCP/IP module on TCP/IP board
XX=9D: Abnormal termination of initialization of TELNET client module on TCP/IP board
XX=9E: Abnormal termination of initialization of TELNET server module on TCP/IP board
XX=9F: Abnormal termination of initialization of FTP module on TCP/IP board
XX=A0: Abnormal termination of initialization of socket interface module on TCP/IP board
XX=A1: Abnormal termination of initialization of TCP/IP board
YY=13: Incorrect channel number
YY=16: Closing the communication line was attempted though it had not been open.
YY=11: Opening the communication line was attempted though it had been open.
YY=11: The program has been activated.
YY=06: A time-out occurred in initialization of TCP/IP board (TCP/IP board is inoperable).
The specified device rejects renaming, canceling its write-protected state, or offering file system information.
Unknown (unsupported) command was used.
YY=0D: No communication board is mounted.
YY=02: The selected program is not found.
YY=08: Execution failed.
Faulty TCP/IP board; communication error; faulty NC program
Properly set the OSP environment setting file.
Correct the communication environment.
Specify an existing file.
