Okuma Alarm-B 2637 No axis movement command
After Geometric transformation G137 commanded, the axis movement instruction is done in first X-Y block.
After 3-D Coordinate conversion G303/G302 commanded, the axis movement instruction is done in first X/Y/Z block.
Program example:
G137
X10 Y20 -> After G137 commanded, there is no axis movement instruction in first X-Y block.
G00 Z10
After G137 commanded, the axis movement instruction is done in first X-Y block.
Program example:
G137
G00 X10 Y20 -> add G00
