Okuma Alarm-B 2663 Turning cut condition interlock
A necessary condition is insufficient in case of the turning cut.
1-> It tried to rotate the work spindle in states other than YI=0 (main axis center), and to execute the cutting feed.
2-> It tried to rotate the spindle in the state that YS axis graphic zero point of the CAS system parameter is not corresponding to the [TURNING POSITION] parameter value and to execute the cutting feed.
3-> It tried to rotate the main axis with the amount of a wick high (YS axis) correction exceeds 1mm, and to execute the cutting feed.
Expected faulty point
Please confirm the NC program.
Moreover, in the case of code=2, the [TURNING POSITION] setting value was changed when this machine adjusts it is thought.
Please confirm the YS graphic zero point setting value and the [TURNING POSITION] setting values.
In the case of code=3, when the amount of a wick high (YS axis) correction exceeds 1mm, the interference detection cannot be done.
Treatment measures
To execute it after it positions it in YI=0, the turnig cut (The cutting feed is done by rotating the work spindle) corrects the processing program.
Moreover, in the case of code=2, it is changed so that YS graphic zero point setting value may agree with the [TURNING
POSITION] setting value by turning off the power and turn it back on again. In old soft version, it is not changed automatically.
Please the same value as the [TURNING POSITION] setting value is set to YS axis graphic zero point in Slant Y axis specification machine.
It is necessary to confirm graphic zero point setting value of other axes, after adjusting the machine.
In the case of code=3, Please cancel CAS function with M867,and process it after confirming no interference.
