Okuma Alarm-B 2678 SPM contour control not possible
Super Precision Machining (SPM) control was attempted when execution of such control is inhibited.
(Super Precision Machining (SPM) control = Hi-Cut Pro or Super-NURBS)
1000000:NURBS mode is selected when the Super-NURBS execution mode is set at OFF.
1010100:NURBS mode is selected during offline servo adjustment.
1010200:NURBS mode is selected during online servo adjustment.
1010300:NURBS mode is selected in the state of command cancel.
1020006:NURBS mode is selected in the cutter radius compensation mode.
1020007:NURBS mode is selected in the 3-D tool offset mode.
102000A:NURBS mode is selected in the fixed cycle mode.
102000C:NURBS mode is selected without selection of feed-per-minute mode.
102003F:NURBS mode is selected in the axis name designation mode.
102004D:NURBS mode is selected in the cylindrical side machining mode.
1020060:NURBS mode is selected in the rapid traverse mode.
2000001:G265/G264 was specified on B-turret.
2000002:G265/G264 was specified on sub-spindle.
2000003:G265/G264 was issued in the tool retraction mode.
2000004:G265/G264 was issued in the HOB mode.
Programming error
Correct the program.
