Okuma Alarm-B 2735 Spindle low rotation command
The spindle low speed command was issued before spindle low speed command conditions are met.
1->The spindle low speed command was issued with the C-axis connected.
2->The spindle low speed command was issued during synchronized rotation.
3->In a flat turning, a Main spindle low speed instruction was done.
4->Main spindle winding/gear conversion instruction (M40-M44) was done in extreme low speed rotation mode.
5->A Main spindle low speed instruction was turned into the Main spindle which an extreme low speed specification does not have selection and it was.
1->Disconnect the C-axis before issuing the low speed command.
2->Cancel the synchronized rotation before issuing the low speed command.
3->After it releases a flat turning, a Main spindle low speed instruction is performed.
