Okuma Alarm-B 2754 Invalid coolant command
In Oil coolant-mode ,water-coolant command are issued.
None->In G14 mode, through spindle-coolant command cannot be issued.
1->In Oil coolant-mode ,water-coolant command are issued.
2->The other high-pressure coolant command when high-pressure coolant commands were specified at the same time.
3->When a auxiliary tool was not mounted in the turret H1, L-tool or through spindle-coolant command.
