Okuma Alarm-B 2767 M-spindle low rotation interlock
The M-spindle low speed command was issued before M-spindle low speed command conditions are met.
1->The M-spindle low speed command was issued with the C-axis not connected.
2->The M-spindle low speed command was issued during synchronized rotation.
3->In a flat turning, M-spindle low speed instruction was done.
4->M-spindle winding conversion instruction (M241/M242) was done in extreme low speed rotation mode.
5->M-spindle low speed instruction was turned into the M-spindle which an extreme low speed specification does not have selection and it was.
6->M519(Spindle extremely low revolution speed mode) commanded when it is not M241(wind(gear) change) condition.
7->M519(Spindle extremely low revolution speed mode) commanded when it is M241(wind(gear) change) condition and spindle rotate or M520(Spindle extremely low revolution speed mode OFF) commanded when spindle rotate.
2->Cancel the synchronized rotation before issuing the low speed command.
3->After it releases a flat turning, M-spindle low speed instruction is performed.
