Okuma Alarm-B 2788 Invalid SB command
An SB command which cannot be executed with the specification selected is specified.
Or SB command was executed when actual ATC tool is lathe cutting tool or ATC cover tool.
1->An SB command which cannot be executed with the specification selected is specified
2->An SB command was executed when actual ATC tool is lathe cutting tool or ATC cover tool.
Check the SB command in a program.
