Okuma Alarm-B 2793 Incorrect attachment index position
When attachment indexing was completed, the actual position differs from the actual position data read from the proximity switch for detecting attachment position.
Index
None = The proximity switch for current position was found to be faulty during the attachment rotation command.
2 = The proximity switch for current C-axis position was found to be faulty after issue of the attachment rotation command.
Hexadecimal number of the position read from the proximity switch for detecting attachment position (unit: 0.1degrees)
The above code is 2: XXXXXYYYY Hexadecimal number (unit: 0.1degrees)
XXXX = Memory of the previous attachment index position
YYYY = The current attachment position
