Okuma Alarm-B 2803 ATC tool data setting
When the manual tool change or ATC operation is attempted, there is an error in the tool data such as next tool command or the data set in the tool-pot correspondence table.
1->There is no setup of the empty pot.
Check if the next tool command is specified correctly and check if the tool data is correctly set by selecting the tool data setting mode.
