Okuma Alarm-B 2805 Limit confirmation impossible
The signal from the proximity switch for detecting attachment position is OFF. The signal pattern sent from the proximity switch cannot be converted into an angle data.
1->The value entered with the C-axis index position confirmation signal has exceeded the range from 0 to 360degrees while the C-axis is not being indexed.
