Okuma Alarm-B 2855 Coolant filter
Coolant filter Error
1->A coolant filter is clogged.
2->The clogged through spindle coolant filter/ input kept OFF for 1 second or longer while the through spindle coolant command is active.
3->The clogged through spindle coolant filter 2/ input kept OFF for 1 second or longer while the through spindle coolant command is active.
1)Coolant filter is clogged. or Float SW is Error in coolant sub tank.
1)Change of a filter or Check a float SW
