Okuma Alarm-B 2915 EXPRESSION Calculation
An error occurred in the operation of expression.
(loader)
XXYY
XX:
bit0->Overflow in addition/subtraction
bit1->Overflow in conversion of ABS into integer
bit2->Conversion from BCD into BIN
bit3->Conversion from BIN into BCD
bit4->Designation of DROUND, DFIX, or DFUP in other than mm unit system.
YY:floating point calculation error
bit0->Overflow in conversion into integer
bit1->Exponent underflow
bit2->Exponent overflow
bit3->Square root of a negative value
bit4->Division by 0
bit5->Overflow in angle
bit6->A numeric value of ASIN is greater than 1.
bit4->Division by 0
Program error
