Okuma Alarm-B 2938 Program analysis complete
Analysis for the next sequence has been completed when an attempt is made to move an axis after changing the operation mode from the program operation mode to the NDI or manual operation mode.
0->Not related with an axis
2->Y-axis(loader)
3->Z-axis
9->C-axis(robot)
1->Analysis for the next sequence has been completed in the program operation mode when an attempt is made to move an axis after changing the operation mode from the program operation mode to the MDI or manual operation mode.
2->Analysis for the next sequence has been completed in the program operation mode when an attempt is made to move an axis using an axis movement key after changing the operation mode from the program mode to the MDI or manual operation mode.
3->Analysis for the next sequence has been completed in the program operation mode when an attempt is made to move an axis using an step feed key after changing the operation mode from the program mode to the MDI or manual operation mode.
Operation error
