Okuma OSP-P300S/P300L Alarm-B list.
For cnc machinists who work on cnc machines with Okuma cnc controls.
Classification Of Okuma Alarms
Alarms related with the OSP are classified into five types, which are
Below are listed Okuma B type alarms for Okuma OSP-P300S/P300L CNC systems.
Okuma Alarm B List
- 2049 PLC axis stroke end over
- 2050 PLC axis command
- 2051 PLC axis continuous positioning over
- 2052 Blue screen
- 2053 P100-Menu error
- 2058 Error occurred while CAS work
- 2059 Non-functioning device detected
- 2060 Fan motor error on panel computer unit
- 2090 The remaining time after relocation has passed
- 2092 MCS Parameter learning error
- 2114 MCS Inertia identification error
- 2120 Overload detected.
- 2132 VDU communication error
- 2133 VDU detected error
- 2134 VDU initialization failure
- 2135 MCS DD encoder link error
- 2136 MCS DD Encoder error
- 2137 MCS DD Encoder (slave sensor) error
- 2138 MCS DD encoder initialization failure
- 2139 MCS DD encoder (slave sensor) initialization failure
- 2144 MCS Power supply unit overload
- 2150 MCS Undefined alarm number
- 2151 MCS Inverter unit fault
- 2152 Mistake in data from MCS to NC
- 2153 MCS CON APA deviation
- 2154 MCS Power supply unit error
- 2155 MCS Converter link error
- 2156 MCS DC-bus voltage alarm
- 2157 MCS Motor overcurrent
- 2158 MCS Power unit overheat
- 2159 MCS Power unit overload
- 2160 MCS Supply voltage flutter
- 2161 MCS Inverter capacity differs from spec.
- 2162 MCS Winding change failure
- 2163 MCS Encoder link error
- 2164 MCS Encoder detected error
- 2165 MCS Encoder initialization failure
- 2166 MCS Encoder with shaft detected error
- 2167 MCS Encoder with shaft initialization failure
- 2168 MCS ABSO SCALE error
- 2169 MCS ABSO SCALE initialization failure
- 2170 MCS Magnetic encoder alarm
- 2171 MCS Resolver alarm
- 2172 MCS Pulse generator count over
- 2173 MCS Motor overheat
- 2174 MCS Servo link error
- 2175 MCS Servo link disconnection
- 2176 Mistake in data from NC to MCS
- 2177 MCS Servo data error
- 2178 MCS Illegal command
- 2179 MCS CON speed over
- 2180 MCS Speed command over
- 2181 MCS DIFF over
- 2182 MCS APA speed over
- 2183 MCS Full-closed APA error
- 2184 MCS Over speed
- 2185 MCS Speed deviation over
- 2186 MCS Collision detected
- 2187 MCS Urgent-stop time over
- 2188 MCS Belt is broken
- 2189 MCS Axis change control error
- 2190 MCS Independent encoder initialization failure
- 2191 MCS Calculated current position lies outside range
- 2192 MCS Motor overload
- 2194 MCS ABSO SCALE sub-slider error
- 2195 MCS Tandem control communication error
- 2196 MCS Full abso scale link error
- 2197 MCS Full abso scale error
- 2198 MCS Full abso scale initialization failure
- 2199 MCS Axis stop signal error
- 2200 G-code error
- 2201 M-code error
- 2202 Common variable error
- 2203 System variable error
- 2204 Sequence name error
- 2205 Numeric data error
- 2206 Character use error
- 2207 Program name error
- 2208 Character string error
- 2209 Hexadecimal data error
- 2210 Spindle max revolution error
- 2212 G132/G133 command error
- 2213 Program factor over
- 2214 Subscript left side incorrect
- 2215 Local variable use over
- 2216 System variable setting data over
- 2217 Output variable setting data mistake
- 2218 UNUSABLE G-code
- 2219 UNUSABLE M-code
- 2220 Subscript left side illegal
- 2221 UNUSABLE output variable No
- 2222 UNUSABLE input variable No
- 2223 UNUSABLE turret direct code
- 2224 UNUSABLE contour generation command
- 2225 UNUSABLE Y-Z circle command
- 2226 UNUSABLE thread cutting command
- 2227 Mnemonic or local variable mistake
- 2228 VSET sequence left command mistake
- 2229 EXPRESSION right side
- 2230 EXPRESSION calculation error
- 2231 EXPRESSION syntax incorrect
- 2232 EXPRESSION subscript mistake
- 2233 EXPRESSION buffer over
- 2234 EXPRESSION local variable
- 2235 Equal does not exist
- 2236 Program end code not found
- 2237 BRANCH (IF,GOTO) sequence name
- 2238 BRANCH(IF,GOTO) condition
- 2239 Mistake in F command
- 2240 Mistake in F/E command
- 2241 Mistake in I command
- 2242 Mistake in J command
- 2243 Mistake in K command
- 2244 Mistake in L command
- 2245 Mistake in P command
- 2246 Mistake in S command
- 2247 No S command
- 2248 Mistake in T command
- 2249 Mistake in X command
- 2250 Mistake in X/Z command
- 2251 Mistake in Z command
- 2252 Mistake in arc command
- 2253 Mistake in angle command
- 2254 Mistake in thread cutting cycle command
- 2255 Mistake in arc radius command
- 2256 Mistake in D command
- 2257 Mistake in gauging cycle command
- 2258 Mistake in C command
- 2259 Mistake in SB command
- 2260 Mistake in QA command
- 2261 Mistake in X/Y command
- 2262 Mistake in incremental command
- 2263 Command required for X-, Y-axes
- 2264 Mistake in Y command
- 2265 Distance calculation over limit
- 2266 Mistake in R command
- 2267 Mistake in drilling cycle command
- 2268 Mistake in angle command
- 2269 Angle chamfering command error
- 2270 Mistake in CD command
- 2271 Mistake in CL command
- 2272 Mistake in TM command
- 2273 Mistake in W command
- 2274 Mistake in CB command
- 2275 Mistake in HP command
- 2276 Mistake in CC command
- 2277 Mistake in torque limit command
- 2278 SUB PROGRAM repetition
- 2279 SUB PROGRAM stack
- 2280 SUB PROGRAM program name
- 2281 SUB PROGRAM data print
- 2282 SCHEDULE PROGRAM ‘Q’
- 2283 SCHEDULE PROGRAM mnemonic code
- 2284 SCHEDULE PROGRAM program end
- 2285 SCHEDULE PROGRAM main program load
- 2286 Plus variable limit over
- 2287 Minus variable limit over
- 2288 User reserve code
- 2289 Unable to write backup data file
- 2290 Program name not selected
- 2291 Main sequence error
- 2292 Restart failure
- 2293 MDI special G-code
- 2294 Special G-code table
- 2295 STM time over
- 2296 UGC No program end code
- 2297 UGC DELETE syntax
- 2298 UGC DEF syntax
- 2299 UGC TIP syntax
- 2300 UGC TIF syntax
- 2301 UGC No shape entry
- 2302 UGC Illegal numerical data
- 2303 UGC Illegal character
- 2304 UGC User variable
- 2305 UGC System variable
- 2306 UGC Illegal command
- 2307 UGC Program factor over
- 2308 UGC Coordinate data
- 2309 UGC END syntax
- 2310 UGC Command over
- 2311 UGC Command format
- 2312 UGC Additional parameter
- 2313 UGC Expression
- 2314 UGC Figure entry area over
- 2315 UGC Unable to delete
- 2316 READ/WRITE No spec
- 2317 READ/WRITE Buffer over
- 2318 READ/WRITE Device No.
- 2319 READ/WRITE Data
- 2320 READ communication error
- 2321 WRITE communication error
- 2322 GET/PUT No spec.
- 2323 GET/PUT Buffer over
- 2324 GET/PUT Number of digits
- 2325 GET/PUT Variable designation
- 2326 GET Numerical data
- 2327 Calculation function no spec.
- 2328 Sub-program no spec.
- 2329 Sub-spindle interference distance
- 2330 Input/output variable no spec.
- 2331 Multiple machining no spec.
- 2332 Sub-spindle no spec.
- 2334 In-process gauging no spec.
- 2335 Post-process gauging no spec.
- 2336 Animation no spec.
- 2337 Graphic backup data file write failure
- 2338 Spindle orientation no spec.
- 2339 Load monitor no spec.
- 2340 Thread phase matching no spec.
- 2341 Circular thread cutting no spec.
- 2342 Circular thread cutting command
- 2343 Tool retract no spec.
- 2344 Tool retract interrupt enable com.
- 2345 Tool retract interrupt disable com.
- 2346 Tool retract interrupt return com.
- 2347 ROBOT no spec.
- 2348 ROBOT program name
- 2349 LOADER no spec.
- 2350 LOADER program name
- 2351 Coupling device program select no spec.
- 2353 CHAMFERING G01 mode
- 2354 CHAMFERING L over
- 2355 CHAMFERING L illegal order
- 2356 CHAMFERING X, Z illegal order
- 2357 CHAMFERING Any angle calculation
- 2358 CHAMFERING Any angle
- 2359 NOSE-R COMP. No spec.
- 2360 NOSE-R COMP. NOSE-R > circle-R
- 2361 NOSE-R COMP. Calculation
- 2362 NOSE-R COMP. Cancel G00 G01
- 2363 NOSE-R COMP. No cross point
- 2364 NOSE-R COMP. Entrance command error
- 2365 NOSE-R COMP. Thread cutting cycle
- 2366 TOOL RADIUS COMP. No spec.
- 2367 TOOL RADIUS COMP. NOSE-R comp. surface change
- 2368 TOOL RADIUS COMP. C-axis separation
- 2369 TOOL RADIUS COMP. QA command
- 2370 TOW-ALONG TAILSTOCK MOVEMENT no spec.
- 2371 TOW-ALONG TAILSTOCK MOVEMENT condition
- 2372 LASER MEASUREMENT no spec.
- 2373 LASER MEASUREMENT condition
- 2374 LAP No spec.
- 2375 LAP B illegal order
- 2376 LAP D illegal order
- 2377 LAP DA(DB) illegal order
- 2378 LAP H illegal order
- 2379 LAP H-U(W) < D (M73)
- 2380 LAP U(W) illegal order
- 2381 LAP U(W) > H
- 2382 LAP XA(ZA), XB(ZB) illegal order
- 2383 LAP Calculation error
- 2384 LAP Down step number over
- 2385 LAP Entry in LAP
- 2386 LAP Sequence name
- 2387 Unable to LAP Control
- 2388 LAP No G-code
- 2389 LAP NOSE-R comp. cancel
- 2390 LAP Entry in NOSE-R comp.
- 2391 LAP Shape designation
- 2392 MULTI CYCLE B illegal order
- 2393 MULTI CYCLE D illegal order
- 2394 MULTI CYCLE F illegal order
- 2395 MULTI CYCLE H illegal order
- 2396 MULTI CYCLE H-U(W) < D (M73)
- 2397 MULTI CYCLE I,K over
- 2398 MULTI CYCLE I,K illegal order
- 2399 MULTI CYCLE L illegal order
- 2400 MULTI CYCLE Entry in LAP
- 2401 MULTI CYCLE U(W) illegal order
- 2402 MULTI CYCLE U(W) > H
- 2403 MULTI CYCLE X,Z illegal order
- 2404 MULTI CYCLE Angle
- 2405 MULTI CYCLE Tool offset
- 2406 MULTI CYCLE Cycle start point
- 2407 MULTI CYCLE Entry in NOSE-R comp.
- 2408 MULTI CYCLE Width
- 2409 TOOL LIFE CONTROL no spec.
- 2410 Tool life management No spare tool
- 2411 TOOL LIFE CONTROL tool group
- 2412 TOOL LIFE CONTROL no T-entry
- 2413 TOOL LIFE CONTROL tool offset group
- 2414 TOOL LIFE CONTROL no T-offset
- 2415 MULTI-MACHINING CYCLE No spec.
- 2416 MULTI-MACHINING CYCLE C
- 2417 MULTI-MACHINING CYCLE I,K
- 2418 MULTI-MACHINING CYCLE Q
- 2419 MULTI-MACHINING CYCLE F
- 2420 MULTI-MACHINING CYCLE L
- 2421 MULTI-MACHINING CYCLE D
- 2422 MULTI-MACHINING CYCLE X,Z
- 2423 MULTI-MACHINING CYCLE SA
- 2424 MULTI-MACHINING CYCLE Feed G94
- 2425 MULTI-MACHINING CYCLE A
- 2426 MULTI-MACHINING CYCLE Thread cycle
- 2427 MULTI-MACHINING CYCLE U,W
- 2428 MULTI-MACHINING CYCLE SB
- 2429 MULTI-MACHINING CYCLE Y-axis mode
- 2430 ATC no spec.
- 2431 ATC syntax
- 2432 ATC TC
- 2434 ATC TL
- 2435 ATC MT
- 2436 ATC MG
- 2438 Unable to M06/M228 command
- 2440 Y-axis no spec.
- 2441 2 saddle machine no spec.
- 2444 Carrier axis variable limit over
- 2445 3-D coordinate conversion
- 2452 Chuck barrier area
- 2453 Tailstock barrier area
- 2456 W-axis minus variable limit over
- 2457 X-axis correction stroke end over
- 2459 Restart axis position is illegal
- 2460 Change timing G13/G14
- 2462 Change timing G122/G123
- 2463 Change timing G140/G141/G142
- 2464 Spindle/turret G-code
- 2465 G122/G123 command mismatch
- 2466 Unable to issue M100 command during Nose-R comp.
- 2472 Y-axis control mode
- 2475 W-axis command G-code
- 2476 Mirror image coordinate selection
- 2477 Sub-spindle mode
- 2478 No workpiece coordinate mode command
- 2479 Contour generation calculation error
- 2480 G132/G133 command error
- 2486 NC turret no spec.
- 2487 Unable to select coordinates
- 2488 UNUSABLE X-axis command
- 2489 NC tailstock parameter error
- 2490 Chuck pressure out of range
- 2491 Horizon barrier intrusion
- 2492 Interrupt program: illegal command
- 2493 Linked external equipment program selection
- 2494 Chuck pressure command illegal
- 2495 Inverse time feed command format
- 2496 CAM data cannot be transmitted.
- 2497 T code
- 2498 Learning cannot be executed.
- 2499 Spindle marker latch data error
- 2500 MULTI-MACHINING CYCLE HS,HI,HJ,HK
- 2501 Recovering synchronous error
- 2502 Block Delete command error
- 2503 End sequence name error
- 2504 PREMIUM THREAD Command error
- 2505 CAM machine no spec.
- 2506 Tool center point control not possible
- 2507 CHP command error
- 2508 Machining mode command format
- 2509 MULTI-MACHINING CYCLE Return point
- 2510 Mistake in torque skip cycle command
- 2511 Remote buffer operation
- 2512 M-tool spindle overload
- 2513 Coordinate calculation
- 2514 MULTI CYCLE C-axis shift
- 2515 Remote buffer operation time out
- 2516 Remote buffer operation communication error
- 2517 W-axis control mode
- 2518 Synchronized tapping command
- 2519 Tailstock control command
- 2520 Mistake in TP command
- 2521 Mistake in BT command
- 2522 Mistake in BA command
- 2523 Thermistor error
- 2524 Mistake in AT command
- 2525 Chuck coordinate change condition
- 2528 Program selection unsuitable
- 2529 Thermal deviation compensation
- 2530 Machining process instruction no.
- 2531 Mirror turning mode
- 2532 System variable set condition error
- 2533 Steady rest over interference pos.
- 2534 LBB turret rotation impossible
- 2536 Coordinate movement rotation copy
- 2537 SLANT PROCESS MODE
- 2538 Incorrect system variable
- 2539 Mistake in B command
- 2541 PROGRAM PRINT command
- 2542 Feed axis retract function command
- 2543 Turret index error position
- 2544 TOOL-ID TOOL DATA
- 2545 MULTI-MACHINING CYCLE LD
- 2546 MULTI-MACHINING CYCLE LK
- 2547 No decimal point
- 2548 X-, Z-axis synchronized feed mode
- 2549 Tool no. mismatch after ATC sequence restart
- 2550 Home position no spec.
- 2551 External home position command
- 2552 Barrier area
- 2555 Linear guide cover interference area command
- 2557 Illegal steady rest command
- 2558 Turning position selection
- 2559 Attachment rotation not possible
- 2561 Illegal system command variable
- 2562 Tool posture fluctuation reduction
- 2563 Mistake in TE command
- 2564 Index disable position
- 2565 Load monitor system variable
- 2566 MULTI-MACHINING CYCLE No M-tool cycle command
- 2567 No helical cutting specifications
- 2568 Mistake in OF command
- 2569 Thermal deviation comp. backup failure
- 2570 W-axis position condition
- 2571 W-axis position no spec.
- 2572 Mistake in RC command
- 2573 Taper cutting cycle
- 2575 Mistake in ‘TD’,’TDG’,’OS’ commands
- 2576 Mistake in H command
- 2577 No axis movement command
- 2578 NO D COMMAND
- 2579 NO L COMMAND
- 2580 Mistake in XS command
- 2581 CAM data deployment mode
- 2582 CAM data file write protect
- 2583 Compensation value overflow
- 2584 CON speed XS-axis
- 2585 XS-axis command turret mode
- 2586 Synchronous mode execution impossible
- 2587 No A command
- 2588 Mistake in OF command
- 2589 Definition conditions
- 2590 Y-axis command
- 2591 Mistake in point command
- 2592 Transport barrier entry command
- 2593 Mistake in CF command
- 2594 Mistake in RJ command
- 2595 Synchronized rotation speed over
- 2596 Synchronized tap overload
- 2597 G15 command
- 2598 No Spec code. “Tool information management spec”
- 2599 Command not possible while mounting LBB.
- 2600 LAW-V machine no spec.
- 2601 Unable to issue T/TE command simultaneously
- 2602 SCHEDULE PROGRAM main program load
- 2603 Spindle rotation fluctuation control no spec.
- 2604 Tow-along steady rest no spec.
- 2605 Tow-along tailstock no spec.
- 2606 READ/WRITE file open
- 2607 Mistake in AP command
- 2608 Mistake in ON command
- 2609 A-axis control no spec.
- 2610 Zero offset select inpossible
- 2611 Spindle fluctuation control no spec.
- 2612 Mistake in TR command
- 2613 Mistake in MTM command
- 2614 Mistake in MTS command
- 2615 Mistake in MGS command
- 2616 B-axis mode
- 2617 Zero setting condition
- 2618 Workpiece detection sensor not ready
- 2619 Mistake in SW command
- 2622 Unset system variable read
- 2623 B-axis no spec.
- 2624 Tow-along steady rest type-B no spec
- 2625 Tow-along steady rest movement condition
- 2626 W-axis overlap
- 2628 Mistake in TW command
- 2629 Mistake in FW command
- 2630 Mistake in SC command
- 2631 DNC-DT Path name
- 2632 DNC-DT Program select
- 2633 DNC-DT Preload error
- 2634 DNC-DT Delete error
- 2635 Y-axis mode
- 2637 No axis movement command
- 2638 A/B saddle synchronized motion command
- 2639 Unable to issue C-axis command during helical cutting
- 2640 AC thread rotation count error
- 2641 AC thread fluctuation control not possible
- 2642 READ/WRITE No empty SAT
- 2643 READ/WRITE File open
- 2644 Unusable PRINT request
- 2645 YS-axis position
- 2646 SYSTEM VARIABLE C-axis separation
- 2648 MG tool ready cycle no spec.
- 2649 SYSTEM VARIABLE Y-axis mode
- 2650 SYSTEM VARIABLE B-axis mode
- 2651 C-axis multi rotation mode
- 2652 Mistake in HA command
- 2653 Mistake in MN command
- 2654 Hob circular cutting command
- 2655 Hob cutting command
- 2657 SYSTEM VARIABLE C-axis connect
- 2658 B-axis independent encoder error
- 2659 NC tailstock position error
- 2662 NC TAILSTOCK no spec.
- 2663 Turning cut condition interlock
- 2667 X-axis mirror image coordinates selected
- 2668 X-axis mirror image coordinates impossible
- 2671 C-axis sync control no spec.
- 2672 C-axis sync command format
- 2674 Default status macro cannot be executed
- 2675 Tool posture command error
- 2676 Tool posture command angle conversion error
- 2677 Attachment change not possible
- 2678 SPM contour control not possible
- 2679 Mistake in Q command
- 2682 Magnetic encoder speed detection error
- 2683 MCS Rotary encoder 5 initialization failure
- 2684 MCS Rotary encoder 5 error
- 2685 MCS Rotary encoder 4 initialization failure
- 2686 MCS Rotary encoder 4 error
- 2687 MCS Rotary encoder 3 initialization failure
- 2688 MCS Rotary encoder 3 error
- 2689 MCS Rotary encoder 2 error
- 2690 MCS Rotary encoder 1 initialization failure
- 2691 MCS Rotary encoder 1 error
- 2692 MCS Linear scale 4 initialization failure
- 2693 MCS Linear scale 4 error
- 2694 MCS Linear scale 3 initialization failure
- 2695 MCS Linear scale 3 error
- 2696 MCS Linear scale 2 initialization failure
- 2697 MCS Linear scale 2 error
- 2698 MCS Linear scale 1 initialization failure
- 2699 MCS Linear scale 1 error
- 2700 No workpiece confirmation error
- 2701 Sequencer Error
- 2702 Spindle command during C-axis connection
- 2703 Chucking miss
- 2704 Chucking miss air off order impossible
- 2705 Tailstock quill over advance
- 2706 Polygon cutting command condition
- 2707 Invalid command during polygon cutting
- 2708 Invalid rotation tool gear
- 2709 Sub-spindle synchronization interlock
- 2710 Sub-spindle synchronization cutting
- 2711 Door open
- 2712 ATC no spec.
- 2713 Invalid ATC syntax
- 2714 Invalid ATC TC no.
- 2716 Invalid ATC TL no.
- 2717 Invalid ATC MT no.
- 2718 Invalid ATC MG no.
- 2719 Invalid ATC command
- 2720 M06/M228 interlock
- 2721 Turret number mismatch
- 2722 Robot/Loader request illegal
- 2723 ATC next tool preparation interlock
- 2724 Invalid ATC sub arm
- 2725 Invalid RS tool L/M
- 2726 Magazine encoder read
- 2727 Magazine rotation interlock
- 2728 Invalid magazine tool no.
- 2729 No magazine return pot
- 2730 Tool insertion interlock
- 2732 Tailstock sleeve position data error
- 2733 Coolant flow
- 2734 Coolant level
- 2735 Spindle low rotation command
- 2736 SVP time constant switching no spec.
- 2737 Invalid tailstock switch position
- 2738 Synchronous hobbing interlock
- 2739 Invalid synchronous hobbing mode
- 2740 Incorrect magazine tool data
- 2741 Touch setter unlock time over
- 2742 Setup switch ON
- 2743 Irregular coolant level
- 2744 Tool breakage
- 2745 Low high-pressure coolant pressure
- 2746 Hydraulic oil unit error
- 2747 Index disable position
- 2748 CPU fan stop
- 2749 Hydraulic oil level lower limit
- 2750 Tool monitoring unit error detection
- 2751 Coolant/Oil mist command
- 2752 Air pressure
- 2753 Unable to change tool
- 2754 Invalid coolant command
- 2755 Semi-dry unit error
- 2756 Actual tool data setting
- 2757 Oil mist unit error
- 2758 Invalid position data
- 2759 Coolant discharge error
- 2760 Sub-spindle rotation tool interlock
- 2761 W-axis overlap mode
- 2762 Chucking miss
- 2763 Coolant filter
- 2764 Coolant error
- 2765 Chip conveyer filter clogged
- 2766 Invalid M-tool spindle command
- 2767 M-spindle low rotation interlock
- 2768 Program check mode interlock
- 2769 Invalid spindle control command
- 2770 SVP time constant switching command
- 2771 APC clamp confirmation
- 2772 APC system mode
- 2773 APC M command
- 2774 Thread cutting cycle interlock
- 2775 Sensor head interlock
- 2776 M command not completed
- 2777 Cross rail positioning sensor error
- 2778 Cross rail motor overload
- 2779 Axis lube motor overload
- 2780 Axis lube pressure ON confirmation
- 2781 No AT command
- 2782 Axis lube pressure OFF confirmation
- 2783 Oil hole motor overload
- 2784 Invalid MT command
- 2785 Invalid AT command
- 2786 No S command
- 2787 No SB command
- 2788 Invalid SB command
- 2789 Coolant tank filter clogged
- 2790 Shower coolant motor overload
- 2791 M spindle head cooling unit
- 2792 Invalid RH command
- 2793 Incorrect attachment index position
- 2794 Mist air lube unit
- 2795 Warming up error
- 2796 Sequence restart
- 2797 Axis interlock release
- 2798 Invalid BC command
- 2800 Alarm detected from externally connected device
- 2801 Turret rotation interlock
- 2802 Invalid long boring bar command
- 2803 ATC tool data setting
- 2804 Attachment control
- 2805 Limit confirmation impossible
- 2806 Door interlock
- 2807 Invalid M code
- 2848 Chip conveyer overload
- 2849 Sensor unit in interference range
- 2850 External request interlock
- 2851 Machine change M-code
- 2852 Hand open/close interlock
- 2853 Teaching operation interlock
- 2854 Machine linked M-code
- 2855 Coolant filter
- 2856 Coolant motor overload
- 2857 UNUSABLE M-code
- 2858 Hand slide advance interlock
- 2887 Coupling device interlock
- 2888 Lube tank level
- 2890 Workpiece clamp miss
- 2891 Tailstock air miss
- 2892 Unable to execute air shut-off command
- 2893 Hydraulic oil controller faulty
- 2894 Spindle lubricant controller error
- 2895 Coolant controller error
- 2896 No touch setter
- 2897 Unloader no spec.
- 2898 Unloader interference position
- 2899 Gauge error
- 2900 DIRECTION V variable
- 2901 DIRECTION Check address
- 2902 DIRECTION Data operation
- 2903 DIRECTION Character use
- 2904 DIRECTION Numerical data
- 2905 DIRECTION Parameter/point
- 2906 DIRECTION Register
- 2907 DIRECTION F
- 2908 DIRECTION E
- 2909 DIRECTION Sequence no.
- 2910 UNUSABLE G-code
- 2911 UNUSABLE M-code
- 2912 UNUSABLE Address character
- 2913 UNUSABLE Mnemonic
- 2914 UNUSABLE Left side direction
- 2915 EXPRESSION Calculation
- 2916 EXPRESSION Syntax
- 2917 EXPRESSION Right side
- 2918 EXPRESSION Left side
- 2919 EXPRESSION Buffer over
- 2920 VARIABLE Buffer over
- 2921 PROGRAM DIRECT Program name
- 2922 PROGRAM DIRECT V variable
- 2923 PROGRAM DIRECT Character use
- 2924 PROGRAM DIRECT G-code
- 2925 BRANCH Sequence name
- 2926 BRANCH Condition
- 2927 Parameter setting illegal
- 2928 Parameter playback impossible
- 2929 Register setting impossible
- 2930 Program plus var. limit over
- 2931 Program minus var. limit over
- 2932 Program request illegal
- 2933 Program request impossible
- 2934 Program external request impossible
- 2935 No program selection
- 2936 No program
- 2937 Program end code
- 2938 Program analysis complete
- 2939 SUB PROGRAM stack
- 2940 SUB PROGRAM Program name
- 2941 SUB PROGRAM Buffer over
- 2942 Command impossible while running
- 2943 Data file read
- 2944 Comment end code not found
- 2945 Equal does not exist
- 2946 No spec.
- 2948 DIRECTION Y
- 2949 DIRECTION Z
- 2950 DIRECTION D
- 2951 DIRECTION L
- 2952 DIRECTION SU
- 2953 DIRECTION Torque limit
- 2954 PROGRAM DIRECT M-code
- 2955 PROGRAM DIRECT Equal
- 2956 Machine change M-code
- 2957 G22 feed
- 2958 Main sequence
- 2959 Barrier limit
- 2960 User reserve code
- 2961 Calculation function no spec.
- 2962 Subscript function no spec.
- 2964 NC program selection
- 2965 EXPRESSION subscript
- 2966 M code time over
- 2967 Cycle time over
- 2968 Program selection
- 2969 G23 FEED
- 2970 DIRECTION X
- 2971 DIRECTION I
- 2972 DIRECTION J
- 2973 DIRECTION K
- 2974 PROGRAM DIRECT hexadecimal data
- 2975 PROGRAM DIRECT character string
- 2976 Stopper position data illegal
- 2977 Program selection unsuitable
- 2978 DIRECTION V
- 2979 DIRECTION C
- 2980 No decimal point
- 2981 DIRECTION Q
- 2982 Time over
