Okuma Alarm-C 3212 DNC Text receipt error
An error is detected in the text during reception or analysis of the text. (Remaining data is ignored.)
Five characters of transfer command and transfer sub command at the beginning of the received text
Content differs depending on the text. For details, refer to the following.
In case of D,MST:
1->Text is received during the interrupt mode. Or reception is made without transmitting C,MST.
2->In the request for coupling mode, response for single mode setting completion is received.
3->In the request for single mode, response for coupling mode setting completion is received.
In case of D,INT:
1->Text is received during the coupling mode. Or reception is made without transmitting C,INT.
2->In the request for interrupt mode ON, request for interrupt mode OFF is received.
3->In the request for interrupt mode OFF, request for interrupt mode ON is received.
In case of C,OPC:
1->Reception is made in a mode other than the coupling mode.
2->Reception is made before responding to all C,OPC for the previous C,OPC.
In case of C,EXE:
1->Coupling mode is not selected.
2->During alarm occurrence (Alarms higher than level C alarms)
3->During machine lock mode
4->During dry run mode
5->Main program is not selected
6->Schedule operation mode is selected.
7->During operation
8->Either one of “Turret-A single operation” and “Turret-B single operation” is selected or both of these are selected.
In case of C,SEL:
2->Reception is made before responding to the C,SEL command received previously.
3->During automatic program selection after turning of power.
4->During warming up sequence
5->During operation
6->Designated file is not found in the memory
7->Error while executing selection (Refer to the error message at the console line for details.)
8->Reception file name contains characters exceeding the designated number, or it contains an illegal character.
9->Gauging file data is being generated.
In case of C,ALM:
In case of C,DEL:
2->Reception is made before responding to the C,DEL command received previously.
3->Designated file is not found in the memory.
4->Designated file is protected.
5->Error while executing deletion. (Refer to the error message at the console line for details.)
6->Reception file name contains characters exceeding the designated number, or it contains an illegal character.
7->Gauging file data is being generated.
In case of D,NCP:
1->Text is received in the single mode or received in the interrupt mode although NC program is not requested by C, NCP command.
2->Finish code “%” exists within the NC program.
3->Finish code “%” does not exist at the end of NC program.
4->In the coupling mode, at reception, the same file name already exists in the memory and the attempt to delete the name is made but the file is protected.
5->Error during the reception of NC program. (Refer to the error message at the console line.)
In case of N,NCP:
1->Interrupt mode is not selected. Or even in the interrupt mode, reception is made although the request for the NC program
with C,NCP is not made.
In case of D,MSG:
1->Coupling mode is not selected. Or reception is made although the request has not been made. (including the doublereception* for the identical page when request is being made)
2->Display page is other than 0 through 3.
3->Display starting position in the horizontal direction is other than 0 through 63.
4->Display starting position in the vertical direction is other than 0 through 13.
In case of C,TOF:
2->Reception is made before responding to the C,TOF received previously.
3->1<=Transfer starting tool offset number<=Transfer completion tool offset number<=32(96)is not satisfied.4->With the single saddle type, data in B column is requested.
In case of D,TOF:
1->Coupling mode is not selected. Or reception is made although the request has not been made. (including the doublereception* after the request)
2->Upper and lower limit error in data
3->Data other than numerical data exists.
4->With the single saddle specification, an attempt to change the data in B column is made.
In case of C,TLM:
2->Reception is made before responding to the C,TLM command previously received.
3->1<=Transfer start tool number<= Transfer completion<=12(63)4->With the single saddle specification, an attempt to change the data in B column is made.
In case of D,TLM
In case of C,COM
2->Reception is made before responding to the C,COM command received previously.
3->1<=Transfer start common variable number<= Transmission completion common variable number <= 32 is not satisfied.In case of D,COM1->Coupling mode is not selected. Or reception is made although the request has not been made. (including the doublereception* after the request)
2->Upper and lower limit error in data.
In case of N,TOF
1->The tool offset data is received although the request has not been made. (including the double-reception* after the request)
In case of N,TLM
1->The tool life data is received although the request has not been made (including the double-reception* after the request).
In case of N,COM
1->The command variable data is received although the request has not been made. (including the double-reception* after the request)
In case of N,MSG
1->The message data is received although the request has not been made (including the double-reception* after the request).
In case of D,STR
1->All data is received although the request has not been made.
In case of D,END
1->All data is received although the request has not been made (although [D.STR] is not received).
In case of N,DTA
In case of C,ATC
2->Reception is made before responding to the [C, ATC] command received previously.
3->1<=Transfer start tool pot number<= Transfer end tool pot number <= 50 is not satisfied.In case of D,ATC1->Coupling mode is not selected. Or reception is made although the request has not been made. (including the doublereception* after the request)
In case of N,ATC
1->The ATC data is received although the request has not been made (including the double-reception* after the request).
*Double-reception:This indicates that the same data ([D,????] or negative acknowledgement[N,???]) is received two times for a single request-to-send command.
Error in text data received
Faulty reception timing
Related Specifications
DNC-C
