Okuma Alarm-C 3218 DNC-B buffer operation change
During the operation in the protocol A, command to switch buffer operation ON/OFF is designated.
Faulty [SET] command data received
Change the buffer operation ON/OFF at the timing when the [SET] command is sent after the completion of machining.
Related Specifications
DNC-B
