Okuma Alarm-C 3264 RS-232C communication illegal
The communication channel could not be properly initialized.
This alarm occurs when an unmounted channel is specified as the communication channel to be used. For the proper use of the post-process gauging unit utilizing RS-232C and the size catcher unit, power must be resupplied.
CN? (RS-232C channel causing the alarm)
XXYY (XX: error code generated when the specified channel is secured, YY: error code generated when the communication
parameter data is set)
XX:
0->The specified channel was secured.
1->communication task is being initialized.
2->RS-232C channel number is wrong.
3->The requested channel is not provided.
4->The identification message address is wrong.
5->The channel is used by a standard function (reader/punch).
6->The channel is used for the other job.
YY:
0->The communication parameter setting is completed.
1->The communication task is being initialized.
2->An RS-232C channel number is wrong.
5->The channel is used for the other job.
6->The command number is wrong.
7->A communication parameter value is wrong.
