Okuma Alarm-C 3279 DNC Machining start conditions
with DNC: Ready to Start Code is sent from Host to NC; when One of the NC Starting Conditions is Not met.
1->Ready to Start Code is sent from Host to NC; when Lathe is under Alarm Status.
2->Ready to Start Code is sent from Host to NC; when Lathe Lock is On.
3->Ready to Start Code is sent from Host to NC; during Lathe Dry-Run.
4->Ready to Start Code is sent from Host to NC; when Lathe Mode is Not Synchronized.
5->Ready to Start Code is sent from Host to NC; when Lathe Mode is Scheduled Program Operation.
6->Ready to Start Code is sent from Host to NC; when No Machining Program is selected.
7->Ready to Start Code is sent from Host to NC; when NC is executing Machining Program.
8->Ready to Start Code is sent from Host to NC; when DNC is sending data.
9->Ready to Start Code is sent from Host to NC; when Parameter is not set as ready to start code in effect.
1: Starting with Push of Operation Panel Start Key is in Effect.
Before issuing Start Command from Host, prepare Lathe, ready to be started (prepare Lathe out of the above Coded Status).
