Okuma Alarm-C 3320 DNC Ethernet receipt error
An error was detected during analysis of received commands.
Index
Character-string that represents the request event requested by the host computer.
Varies depending on the command.
NONE->
1 -> Although the CNC did not sent the mode change request, it received the mode change permission from the host computer.
2 -> In response to the (individual/system link) mode change request, the CNC received the interruption mode change permission.
3 -> In response to the (individual/interruption) mode change request, the CNC received the system link mode change permission.
4 -> In response to the (system link/interruption) mode change request, the CNC received the individual mode change permission.
1 -> The CNC is not in the system link mode.
2 -> The CNC received the operator call processing request although it has not returned the response to the previous operator call processing request.
3 -> Illegal operator call answer was recieved.
3 -> Neither first part machining cancel nor fixture change cancel.
2 -> The CNC received the program selection request although it has not returned the response to the previous program selection request.
3 -> The CNC was in the automatic program selection state to be executed when the power is turned ON.
4 -> The CNC was in the warm-up sequence.
5 -> The CNC was running.
7 -> An error occurred during the execution of program selection.
8 -> Illegal file name was received.
9 -> Illegal device name was received.
2 -> The CNC was in an alarm state (alarm C or higher level alarm).
3 -> The machine lock function was ON.
4 -> The dry run function was ON.
5 -> The main program was not selected.
6 -> The schedule program was selected.
7 -> The CNC was running.
8 -> Either one of “Turret-A single operation” and “Turret-B single operation” is selected or both of these are selected.
9 -> The axis command cancel function was ON.
A -> The STM lock function was ON.
B -> It is not in the operation ready state.
1E-> The CNC was in the warm-up sequence.
2 -> The CNC received the NC reset request although it has not returned the response to the previous NC reset request.
3 -> The CNC was in an alarm state (alarm C or higher level alarm).
1 -> The CNC is in none of the system link, the manual, and the mid-auto manual mode, and neither it is the DNC-C1 specification.
2 -> The CNC received the NC panel status data request although it has not returned the response to the previous NC panel status data request.
2 -> The CNC received the NC status data request although it has not returned the response to the previous NC status data request.
2 -> The CNC received the axis information request although it has not returned the response to the previous axis information request.
2 -> Time data (year) was not in the range of “1980 to 2099”.
3 -> Time data (month) was not in the range of “1 to 12”.
4 -> Time data (day) was not in the range of “1 to 31 (28, 29, 30)”.
5 -> Time data (hour) was not in the range of “0 to 23”.
6 -> Time data (minute) was not in the range of “0 to 59”.
7 -> Time data (second) was not in the range of “0 to 59”.
1 -> In other than the system link mode, the CNC received the data of the page it has not requested.
2 -> Displayed page number is outside the range of “0 to 3”.
3 -> The display start position in the horizontal direction is outside the range of “0 to 63”.
4 -> The display start position in the vertical direction is outside the range of “0 to 12”.
5 -> The received message data exceeded the end position of the screen.
2 -> Illegal file name was received.
3 -> Illegal device name was received.
4 -> The designated file does not exist in the memory.
5 -> An error occurred while NC program was sent.
4 -> In the system link mode, the NC program name of the same file name exists in the memory.
8 -> There is no available memory area.
2 -> The CNC received the NC file delete request although it has not returned the response to the previous NC file delete request.
3 -> The designated file did not exist in the memory.
4 -> The designated file was protected.
5 -> An error occurred during deletion.
6 -> Illegal file name was received.
7 -> The designated file was being run in type B.
3 -> The received tool pot number [start] was outside the range of “1 to Max. pot number”.
4 -> The received tool pot number [end] was outside the range of “1 to Max. pot number”.
5 -> The received tool pot number [start] was larger than the received tool pot number [end].
2 -> The received pot number was outside the range of “1 to Max. pot number”.
3 -> The received tool number was outside the range of “1 to Max. tool number”.
4 -> The received tool kind does not exist.
5 -> The received tool number and tool kind designation is incorrect.
6 -> The received tool pot number [start] was outside the range of “1 to Max. pot number”.
7 -> The received tool pot number [end] was outside the range of “1 to Max. pot number”.
8 -> The received tool pot number [start] was larger than the received tool pot number [end].
9 -> The received data is not the requested pot number data.
A -> The received data is not the pot number data for which the host issues a transmission request.
B -> Data is updated in an ATC cycle.
C -> Data is not updated because the previous data writing cycle is not finished.
2 -> The received tool life management data structure is incorrect. (model-dependent common type; for M/C:0, for NC lathe:1, for M/C (tool ID):2)
3 -> The received tool number [start] was outside the range of “1 to Max. tool number”.
4 -> The received tool number [end] was outside the range of “1 to Max. tool number”.
5 -> The received tool number [start] was larger than the received tool number [end].
6 -> There is data on the B turret side in a state where neither the two-saddle specification nor the opposing turret
specification is selected.
2 -> The received tool number was outside the range of “1 to Max. tool number”.
3 -> The received tool group number is not in the range from 0 to the maximum tool group number.
4 -> The received first tool offset number is not in the range from 1 to the maximum tool number.
5 -> The received second tool offset number was outside the range of “1 to Max. tool number”.
6 -> The received third tool offset number was outside the range of “1 to Max. tool number”.
7 -> The received life setting value was outside the range of “0 to 32767”.
A -> The received tool life management data structure is incorrect. (model-dependent common type; for M/C:0, for NC lathe:1, for M/C (tool ID):2)
B -> The received tool number [start] was outside the range of “1 to Max. tool number”.
C -> The received tool number [end] was outside the range of “1 to Max. tool number”.
D -> The received tool number [start] was larger than the received tool number [end].
E -> There is data on the B turret side in a state where neither the two-saddle specification nor the opposing turret specification is selected.
F -> The received machining number setting or actual machining number is out of the range from 0 to 9999.
10-> The received cutting time setting or actual cutting time is out of the range from 0 to 359999.
11-> The received wear setting or actual wear is out of the range from 0 to 999999.
12-> The received measurement NG flag or life flag is neither 0 nor 1.
13-> The received data is not the requested turret data.
14-> The received data is not the turret data for which the host issues a transmission request.
15-> The received data is not the requested tool number data.
16-> The received data is not the data set attribute for which the host issues a transmission request.
3 -> The received tool offset number [start] was outside the range of “1 to Max. tool number”.
4 -> The received tool offset number [end] was outside the range of “1 to Max. tool number”.
5 -> The received tool offset number [start] was larger than the received tool offset number [end].
6 -> There is data on the B turret side in a state where neither the two-saddle specification nor the opposing turret specification is selected.
2 -> The received tool offset number was outside the range of “1 to Max. tool number”.
3 -> The received tool length offset data was outside the range of “-9999999 to 9999999”.
4 -> The received cutter diameter offset data was outside the range of “-9999999 to 9999999”.
5 -> The received tool life management data structure is incorrect. (model-dependent common type; for M/C:0, for NC lathe:1, for M/C (tool ID):2)
6 -> The received tool offset number [start] was outside the range of “1 to Max. tool number”.
7 -> The received tool offset number [end] was outside the range of “1 to Max. tool number”.
8 -> The received tool offset number [start] was larger than the received tool offset number [end].
9 -> There is data on the B turret side in a state where neither the two-saddle specification nor the opposing turret specification is selected.
A -> The received tool wear compensation data is out of the wear compensation data input range.
B -> The received correction data set count is out of the range from 1 to 8.
C -> The received data set attribute is out of the range from 0 to 7.
D -> The received data is not the requested turret data.
E -> The received data is not the turret data for which the host issues a transmission request.
F -> The received data is not the requested tool correction data.
10-> The received data is not the tool correction data for which the host issues a transmission request.
11-> The received data is not the requested transfer data set count.
12-> The received data is not the transmission data set count for which the host issues a transmission request.
13-> The received data is not the requested data set attribute.
14-> The received data is not the data set attribute for which the host issues a transmission request.
3 -> The received common variable number [start] was outside the range of “1 to Max. common variable number”.
4 -> The received common variable number [end] was outside the range of “1 to Max. common variable number”.
5 -> The received common variable number [start] was larger than the received common variable number [end].
2 -> The received common variable number was outside the range of “1 to Max. common variable number”.
3 -> The received common variable number data was overflow data
4 -> The received common variable number data was minus overflow data.
5 -> The received common variable number data was underflow data.
6 -> The received common variable number data was minus underflow data.
7 -> The received common variable number [start] was outside the range of “1 to Max. common variable number”.
8 -> The received common variable number [end] was outside the range of “1 to Max. common variable number”.
9 -> The received common variable number [start] was larger than the received common variable number [end].
A -> The received common variable number data was “E”.
2 -> The received parameter kind is incorrect.
3 -> The received parameter number [start] was outside the range of “1 to Max. parameter number”.
4 -> The received parameter number [end] was outside the range of “1 to Max. parameter number”.
5 -> The received parameter number [start] was larger than the received parameter number [end].
2 -> The received parameter number was outside the range of “1 to max. parameter number”.
3 -> The received parameter data was outside the range of “Min. value to Max. value”.
4 -> The received parameter kind is incorrect.
5 -> The received parameter number [start] was outside the range of “1 to Max. parameter number”.
6 -> The received parameter number [end] was outside the range of “1 to Max. parameter number”.
7 -> The received parameter number [start] was larger than the received parameter number [end].
1 -> The received tool life management data structure is incorrect. (model-dependent common type; for M/C:0, for NC lathe:1, for M/C (tool ID):2)
2 -> The CNC received the axis load data send request although it has not returned the response to the previous axis load data send request.
1 -> Not in the auto mode
3 -> The received station number [start] is out of the range from 1 to the maximum station number.
4 -> The received station number [end] is out of the range from 1 to the maximum station number.
5 -> The received station number [start] is larger than the received station number [end].
2 -> The received station number is out of the range from 1 to the maximum station number.
3 -> The received tool number is out of the range from 1 to the maximum tool number.
4 -> The received tool type does not exist.
5 -> The received tool number and tool type are incorrect.
6 -> The received station number [start] is out of the range from 1 to the maximum station number.
7 -> The received station number [end] is out of the range from 1 to the maximum station number.
8 -> The received station number [start] is larger than the received station number [end].
9 -> The received data is not the requested station number data
A -> The received data is not the station number data for which the host issues a transmission request.
