Okuma Alarm-C 3321 DNC Ethernet transmission error
While sending a command, an error that disables continuous sending occurred.
Index
Representing the request event requested from the host computer to the CNC.
Varies depending on the command.
1 -> While sending the command in the individual mode, file reading was made impossible.
2 -> The program to be sent in the individual mode was not found in the memory. In this case, the program is not sent.
3 -> The main program to be sent in the individual mode was not selected. In this case, the program is not sent.
