Okuma Alarm-C 3704 Lube tank flow
While lube motor ON time and lube motor OFF time no lubrication oil flow for the slideways has been detected.
(I/O check NO.25 INPUT bit F iBOF)
1->Lubrication oil flow input signal has never been ON.
2->Lubrication oil flow input signal has never been OFF.
3->While XS-axis lube motor ON time and 10 seconds no lubrication oil flow for the slideways has been detected. (-05/2001)
4->[Steady rest types]
[CAM lathe types]
XS-axis lubrication oil flow input signal has never been OFF.
5->Steady rest lubrication oil flow input signal has never been OFF.
7->XS-axis lubrication oil flow input signal has never been OFF.
8->The 2nd lubrication oil flow input signal has never been ON.
9->The 2nd lubrication oil flow input signal has never been OFF.
1)Defective lubrication pump
2)Clogging
3)Breakage of lubricating oil pipe
