Okuma Alarm-C 3709 Coolant level
Coolant is running short or overflown.
None->The coolant level low switch (I/O check NO.34 INPUT bit 0 iCOL/) kept OFF for a second or longer.
1->The coolant level high switch (I/O check NO.35 INPUT bit E iCOLOV/) kept OFF for a second or longer.
2->The coolant level lower limit switch (I/O check NO.43 INPUT bit AiCLLST/) kept OFF for a second or longer.
3->The coolant overflow switch (I/O check NO.43 INPUT bit B iCLOF/) kept OFF for a second or longer.
4->The coolant level upper limit switch (I.035F) kept OFF for a second or longer.
5->The coolant level lower limit switch (I.035E) kept OFF for a second or longer.
6->The coolant ON signal was continuously sent from the high-pressure coolant unit for the time specified by the parameter.
7->The coolant level low switch (I/O check NO.34 INPUT bit 0 iCOL/) kept ON for a second or longer.
8->The input signal of coolant level shortage (I/O check NO.24 INPUT bit 3 iCOL)is ON which is longer than 1 second.
9->The input signal of coolant level shortage (I/O check NO.36 INPUT bit 6 iCOLLO/)is OFF which is longer than 1 second.
10->The lowlevel signal has been OFF for 1[s] or more.
The input which shows a state of a level shortage
(I/O check NO.36 INPUT bit A iOMCL/)
11->The lowlevel signal has been OFF for 1[s] or more.
The input which shows a state of a level shortage(I/O check NO.36 INPUT bit 9 iCLLD/)
12->The lowlevel signal has been OFF for 1[s] or more.
The input which shows a state of a level shortage(I/O check NO.36 INPUT bit A iCOLL/)
13->The lowlevel signal has been OFF for 1[s] or more.
(I/O check NO.36 INPUT bit 9 iOMCL/)
14->[Coolant level low/] signal remained OFF longer than 1[s].
15->The coolant level signal from mist coolant unit was OFF.
16->The Coolant overflow signal kept OFF for 1[s] or longer.
17->The Coolant lowlevel signal with the machine coolant tank kept OFF for 1[s] or longer.
18->The Coolant lowlevel signal with the additional coolant tank kept OFF for 1[s] or longer.
19->The coolant lowlevel signal with the machine coolant tank kept OFF for 30[s] or longer.
20->The lowlevel signal has been OFF for 1[s] or more.
The input which shows a state of a level shortage(I/O check NO.36 INPUT bit 6 iDCOLLO/)
21->The oil mist unit lowlevel signal has been OFF for 1[s] or more.
The input which shows a state of a level shortage(I/O check NO.36 INPUT bit 9 iCOLL/)
22->The coolant level low switch (I/O check NO.21 INPUT bit C iCOL/)for R-side kept OFF for a second or longer.
23->The coolant level low switch (I/O check NO.36 INPUT bit F i2COL/)for L-side kept OFF for a second or longer.
24->The coolant level low switch (I/O check NO.34 INPUT bit 0 iCOL/) kept OFF for the time of parametar setting or longer.
25->Oil inside oil mist for A turret was shortage.
26->Oil inside oil mist for B turret was shortage.
27->Oil inside oil mist for A turret was overflown.
28->Oil inside oil mist for B turret was overflown.
29->The coolant level low switch kept OFF for a second or longer.
30->The Coolant upper limit signal with the conveyer tank kept ON for 2[s] or longer.
31->The Coolant low limit signal with the conveyer tank kept ON for 2[s] or longer.
32->The Coolant low limit signal with the separator tank kept ON for 2[s] or longer.
33->The coolant high-level signal (iDTHIL/) with the dirty coolant tank kept OFF.
34->The coolant high-level signal (iCTHIL/) with the clean coolant tank kept OFF.
35->The coolant low-level signal (iCTLOL/) with the clean coolant tank kept OFF.
36->The coolant level in the coolant filter unit is high.
The high-level signal (iFCHIL/) is OFF.
37->The coolant level low switch kept OFF within the parameter-set time after the program end(M02/M30).
38->The Coolant lowlevel signal with the machine and additional coolant tank kept OFF for 1[s] or longer.
39->A problem has occurred with machine coolant level switches.
40->A problem has occurred with additional coolant level switches.
41->Alcohl tank level lower limit.
42->The coolant tank level normal signal went OFF when the coolant command was issued.
43->The coolant tank level normal signal went OFF when the oil hole (through spindle coolant) command was issued.
44->The coolant tank level normal signal went OFF when the shower coolant command was issued.
45->The coolant tank level normal signal went OFF when the chip flush-out command was issued.
46->The coolant tank level normal signal went OFF when the work washing gun command was issued.
47->The Coolant lowlevel signal with the additional coolant tank kept OFF for 5[s] or longer.
48->The coolant tank level normal signal went OFF when the ANG head coolant command was issued.
49->The high pressure oil hole (through spindle coolant) tank is level low.
1)Coolant level
2)Float switch position
3)Malfunction of float switch
For code 36->The coolant filter is clogged.
Malfunction of high-level switch.
1)Replenish coolant.
2)Check the float switch.
3)Change the float switch.
For code 36->Change the coolant filter.
Change the high-level switch.
