Okuma Alarm-C 3713 Chip conveyer overload
On the machine with CE marking specifications, the chip conveyer overload function is activated.
If “1” is set at MC USER PARAMETER No.19 CHIP CONVEYER”1. Chip conveyer over load alarm-D” the alarm D 4701 Chip conveyer overload occurs instead of this alarm.
None->The overload of the chip conveyer motor is tripped.
1->The overload of the 1st inside machine conveyer motor is tripped.
2->The overload of the 2nd inside machine conveyer motor is tripped.
3->The overload of the scraper conveyer motor is tripped.
4->The overload of conveyer reverse pump motor is tripped.
The chip conveyer motor is put under excessive load.
Check the chip conveyer for clogging with chips.
