Okuma Alarm-C 3729 Coolant error
High-pressure coolant alarm input signal is OFF.
Both upper limit float switch and lower limit float switch signals are OFF or coolant alarm signal is OFF.
The centrifugal separator alarm (contact B) input signal turned OFF.
The clogged thickener separator signal turned ON.
1->In the case of concentrated coolant specification, both upper limit float switch and lower limit float switch signals are OFF.
2->In the case of concentrated coolant specification, coolant alarm signal is OFF.
3->The centrifugal separator alarm input signal turned OFF.
4->The clogged thickener separator signal turned ON.
5->The centralized coolant unit was faulty or saving energy when a coolant supply command was issued or coolant was being supplied (for centralized coolant types).
6->High-pressure coolant unit warning (B-type contact) input signal is OFF in high-pressure coolant system, which is made by chip blaster.
7->In the case of concentrated coolant specification, coolant pressure 1 signal is OFF.
8->In the case of concentrated coolant specification, coolant pressure 2 signal is OFF.
9->The coolant level of the high pressure coolant unit is low.
10->The filter of the high pressure coolant unit is clogged.
11->The pump illegal when high-pressure coolant supply.
12->In the case of concentrated coolant specification,the pressure of coolant is low.
13->The coolant collect pump normal input signal kept OFF for 3 seconds or longer while the through spindle-coolant command is active.
