Okuma Alarm-C 3895 Coolant controller error
1->The coolant controller alarm/signal (I.025B) kept OFF for a second or longer.
2->The coolant cooler alarm/signal (I.0366) kept OFF for 2 seconds or longer.
3->The coolant controller alarm/signal (I.0366) kept OFF for 2[s] or longer.
4->The coolant controller alarm/signal (I.0350) kept OFF for a second or longer.
5->The coolant cooler alarm signal 1(iCLOCA1/) turned OFF.
6->The coolant cooler alarm signal 2(iCLOCA2/) turned OFF.
7->The coolant cooler alarm/signal kept OFF for 3[s] or longer.
The coolant oil controller motor is put under excessive load.
1)Overload for coolant oil controller motor.
1) Check the motor for coolant oil controller.
