Okuma Alarm-D 4773 ATC shutter barrier area
The turret has entered the interference zone between ATC shutter and machine cover.
1->When ATC shutter is not closed, the turret has entered the interference zone between ATC shutter and machine cover set at machine parameter
2->When ATC shutter is not closed, the turret has entered the interference zone between ATC shutter and machine cover set at machine parameter
3->When ATC shutter is not opened, the turret has entered the side of minus more the ATC Home position(P5).
Perform it in the following procedure when this machine is mode to carriage return from this alarm generation state.
1) Move the turret away from the ATC shutter interference position(+) by pulse handle, or close the ATC shutter.
2) Move the turret away from the ATC shutter interference position(-) by pulse handle, or close the ATC shutter.
3) Move the turret away from the ATC shutter interference position(+) by pulse handle, or open the ATC shutter.
