Okuma Alarm-D 4782 Workpiece stocker error
1->The material preparation cycle time became exaggerated.
2->The product table preparation cycle time became exaggerated.
3->The stocker changing cycle time became exaggerated.
4->The prepatation cycle command is designated when not being the work stocker origin position.
5->In the 2 lift work stocker specifications, the out lifter was full work when there was work on the in lifter.
6->The material preparation cycle command or the material/product table preparation cycle command is designated when the in lifter was lower position and there was work on the in lifter.
7->Area sensor was shuted, when material feed lamp is not turning.
8->With all the work was detected by lower sensor, the lift moved upper limit when the work does not detected by upper sensor.
1)Turn on the manual interrupt switch.
