Okuma Alarm-D 4867 M-spindle angle uncertain
None->Concerning the optical measure within a machine specification,when a power supply of a machine was turned on, a sensor was mounted on turret and M-spindle angle was uncertain.
1)Select manual operation mode.
2)Push “turret index cutting position” button on ATC operation panel.
3)Index T3 turret by “turret index” button.
4)Push “manual tool exchange button” on ATC operation panel.
5)Remove a sensor from turret by #turret tool unclamp” button.
6)Push “turret tool clamp” button.
7)Cancel T3 turret information of parameter.
8)Cancel manual tool exchange mode by pushing “manual tool exchange” button.
9)Push “turret index ATC position” button on ATC operation panel for M-spindle orientation.
10)Index T3 turret again by turret index button. And, M-spindle is done orientation.
11)Push “manual tool exchange” button on ATC operation panel.
12)Push “turret tool unclamp” button.
13)Attach a sensor again and push “turret tool clamp” button.
14)Set T3 turret information of parameter.
