Okuma Alarm-P 0701 P100-Menu initialization failure
An error occurred in P100-Menu while system startup.
1: NC Control file was not found.
2: PLC Control file was not found.
3: NC-HMI was not found
4: 3D real sim file was not found.
5: MacMan file was not found.
6: Version mismatch between P100-Menu and PLC Control
7: Version mismatch between P100-Menu and MacMan
8: Version mismatch between P100-Menu and NC Control
11: Conf-P100-menu read error
12: An error occurred at RTOS
13: An error occurred at UPS Service
21: NC Control start failure
22: Error in obtaining shared objects
23: PLC Control start failure
24: NC-HMI start failure
25: 3D real sim start failure
26: MacMan start failure
101: Startup sequence 0x10 receive failure
200: Startup sequence 0x10 send failure
201: Startup sequence 0x20 receive failure
300: Startup sequence 0x20 send failure
301: Startup sequence 0x30 receive failure
400: Startup sequence 0x30 send failure
401: Startup sequence 0x60 receive failure
500: Startup sequence 0x60 send failure
501: Startup sequence 0x70 receive failure
600: Startup sequence 0x70 send failure
601: Startup sequence 0x7C receive failure
700: Startup sequence 0x7C send failure
701: AlarmService start failure
702: Activation sequence 0x80 receive failure
1.Execution file name failure
2.Data file name failure
3.RTOS failure
4.UPS function failure
5.Software failure
6.Software Version failure
