Okuma Alarm-P 0757 MF-SAFETY Error
An error was detected by the MF-SAFETY.
0x1000XXXX->CPU Exception was occurred in the MF-SAFETY
XXXX->Exception number
0x1100XXXX->NMI was occurred in the MF-SAFETY
XXXX->NMI code
bit15->An error was occurred
bit9 ->Voltage drop for CPU1
bit8 ->Watchdog timer overflow in CPU0
bit1 ->Voltage drop for CPU0
bit0 ->Watchdog timer overflow in CPU1
0x1200XXXX->CPU bus error was occurred in the MF-SAFETY
XXXX->CPUID
bit15->CPUID (0:CPU0, 1:CPU1)
0x130000XX->No response in CPU1 request
XX->CPU1 request number
0x170000XX->Normal process in the MF-SAFETY did not end within a specific period.
XX->End time of normal process (1bit=62.5us)
0x1800XXXX->An Error was detected by the MF-SAFETY
XXXX->Error Code
bit15->MFU I/O unit error
bit14->MFU I/O Bus parity error
bit12->Synchronization error
bit11->Wrongly set synchronous signal timing
0x19000000->Stack overflow in the MF-SAFETY CPU
0x1A00XXXX->Illegal address is in the label table
XXXX->Index of label table
0x1B000000->NC starts up with software update mode in the MF-SAFETY
0x1C0000XX->Mode setting is mismatch between NC and MF-SAFETY
XX->Mismatch location
01->MF-SAFETY mode setting is wrong
02->NC mode setting is wrong
MF-SAFETY
NC mode setting
I/O unit in MFU
Replace the MF-SAFETY unit
Replace the I/O unit in MFU
Switch(SW1) of the MF-SAFETY turns off
Update the MF-SAFETY software (safety logic)
