Okuma Alarm-P 0808 Speed change ratio failure
On the machine with high speed profiling function,an improper speed change ratio is set on X, Y, Z, or Caxis or a wrong type of position encoder is used.
1->Xaxis speed change ratio is set with a code.
2->Yaxis speed change ratio is set with a code.
3->Zaxis speed change ratio is set with a code.
4->Caxis speed change ratio is set with a code.
5->Xaxis speed change ratio exceeds the setting range.
6->Yaxis speed change ratio exceeds the setting range.
7->Zaxis speed change ratio exceeds the setting range.
8->Caxis speed change ratio exceeds the setting range.
9->A wrong type of position encoder is used.
Speed change ratio data in the servo data PBU file,or encoder type
Correct the servo data PBU file.
