Okuma Alarm-P 0823 AXIS CONSTRUCTION DATA setting error
The axis construction setting, specified by the axis construction number, is not set correctly.
XY
X=1 ->In the system of axis construction setting, setting of “2” exists without the setting of “1”.
Y=2 ->”0″ is set for any of the setting items of the construction setting of the axis which is made valid by the control axis bit data (PLC -> NC bit data U.).
Y: Axis construction number setting value
Axis construction setting
Set the axis construction setting correctly according to the alarm code.
