Okuma Alarm-P 0828 Wire feed axis No. error
The axis specified by the wire feed axis number (PLC -> NC word data WU) is not an infinite linear axis.
The wire feed axis number is “0”. The wire feed axis number is larger than “7”. In the test mode, an infinite linear axis is not set in the axis construction setting.
Wire feed axis number
PLC sequence program
Correct the PLC sequence program.
