Okuma Alarm-P 0845 Specification code setting failure
The set specification code is not selectable.
A required specification code is not set.
Specification codes are inconsistently combined.
1-> All the machine types are OFF at the machine model specification code.
1) Machine type is not set at the machine model specification code.
1) If the NC was running normally before alarm, install the control software.
2) If the NC did not run after installation of the control software before alarm occurrence, check the control floppy data (file name) and remake the floppy.
