Okuma Alarm-P 0849 Synchronous axis tandem control initialization failure
ERROR occurred in intial changing of synchronism-axis of tandem control.
Axis or None
XXYY
XX=Cause YY=Pair Number
=1:The tandem control specification cord of master-axis is not “1”.
=2:The master-tandem control specification cord of master-axis is not “1”.
=3:The tandem control specification cord of slave-axis is not “1”.
=4:The master-tandem control specification cord of slave-axis is not “0”.
=5:A master-axis of synchronism-axis is not found.
=6:A slave-axis of synchronism-axis is not found.
=7:Master-axis and slave-axis are not connected in the same link(channel).
=8:Link connection order of master-axis and slave-axis is not order of master,slave.
=9:The slave-station for communication can not be assurance.
XX=1:Amend or change the servo data file
=2:Amend or change the servo data file
=3:Amend or change the servo data file
=4:Amend or change the servo data file
=5:Reseach application-soft
=6:Reseach application-soft
=7:Connect master-axis and slave-axis in the same link.
=8:It is connected in order of master,slave.
=9:The number of the largest connection axis of link for master-axis and slave-axis is 7.
Okuma Alarm-P 0849 Synchronous axis tandem control initialization failure=3:Amend or change the servo data file
