Okuma Alarm-P 0957 Graphic backup data file read
Graphic backup data file cannot be read from the memory.
1-> The backup file does not exist in the memory, or a wrong name is designated.
2-> File type is not “PBU1”.
3-> DB size for the file is tool large.
4-> DB size for the file is tool small.
1)If the NC was normally running before occurrence of this alarm, the graphic data file must have been deleted or destroyed.
2)If the NC had never run after installation of the control software until occurrence of this alarm, the graphic data file must be wrong in type or the control software did not include the file.
Operation Example
The operator has deleted the graphic backup data file by mistake.
In the case of 1) reinstall the control software.
In the case of 2) check the control floppy (for file name, etc.) and remake the floppy.
Related Specifications
Graphic Specification
