Okuma OSP-P300S/P300L Alarm-P list.
For cnc machinists who work on cnc machines with Okuma cnc controls.
Classification Of Okuma Alarms
Alarms related with the OSP are classified into five types, which are
- Alarm P (listed below)
- Alarm A
- Alarm B
- Alarm C
- Alarm D
- ERROR
Below are listed Okuma P type alarms for Okuma OSP-P300S/P300L CNC systems.
Okuma Alarm P List
- 0700 NC start-up error
- 0701 P100-Menu initialization failure
- 0702 Power failure upon start-up
- 0703 Load information file not found
- 0704 File load error
- 0705 Default scheduling table error
- 0706 Backup data file error
- 0707 DTL link/unlink error
- 0708 RT thread stack overflow
- 0709 Hardware exception
- 0710 System call error
- 0711 AlarmService library error
- 0712 AlarmService internal error (exception)
- 0713 AlarmService error
- 0714 Blue screen
- 0715 P100-Menu error
- 0716 Floating point exception
- 0717 PLC control error
- 0718 Real time thread time over
- 0719 HXCP thread error
- 0720 AlarmService internal error
- 0721 DeviceNet error
- 0723 DeviceNet I/O data link file read
- 0725 M code data file
- 0726 Safety speed data error
- 0727 MCS firmware doesn’t support POS2 unit
- 0728 FL-net error
- 0729 Non-responsive software detected.
- 0731 R Spec. error
- 0732 Unable to execute lost motion compensation
- 0735 MCS DD encoder link error
- 0736 MCS DD encoder error
- 0737 MCS DD encoder (slave sensor) detected error
- 0738 MCS DD encoder initialization failure
- 0739 MCS DD encoder (slave sensor) initialization failure
- 0741 MCS firmware version error
- 0742 Relocation detection error
- 0744 MCS power supply unit overload
- 0750 The spec.-code or select-soft. was wrong
- 0752 VDU communication error
- 0753 VDU detected error
- 0754 VDU initialization failure
- 0755 SIO link error
- 0756 PSC optical scale encoder error
- 0757 MF-SAFETY Error
- 0758 Safety I/O Error
- 0759 Safety Servo Link Error
- 0782 Magnetic encoder speed detection error
- 0783 MCS Rotary encoder 5 initialization failure
- 0784 MCS Rotary encoder 5 error
- 0785 MCS Rotary encoder 4 initialization failure
- 0786 MCS Rotary encoder 4 error
- 0787 MCS Rotary encoder 3 initialization failure
- 0788 MCS Rotary encoder 3 error
- 0789 MCS Rotary encoder 2 error
- 0790 MCS Rotary encoder 1 initialization failure
- 0791 MCS Rotary encoder 1 error
- 0792 MCS Linear scale 4 initialization failure
- 0793 MCS Linear scale 4 error
- 0794 MCS Linear scale 3 initialization failure
- 0795 MCS Linear scale 3 error
- 0796 MCS Linear scale 2 initialization failure
- 0797 MCS Linear scale 2 error
- 0798 MCS Linear scale 1 initialization failure
- 0799 MCS Linear scale 1 error
- 0800 Spindle D/A control data file read
- 0801 TCP/IP board detected error
- 0802 Load information file not found
- 0803 File load error
- 0804 MSB file mismatch
- 0805 MOP-Tool parameter PBU load
- 0806 MOP-Tool tool data PBU load
- 0807 ACP panel status receipt error
- 0808 Speed change ratio failure
- 0810 NC I/O data file read
- 0812 MCS initialization error
- 0813 MCS Communication error
- 0814 MCS data file corrupt
- 0815 PLC real-time task loop error
- 0816 PLC initialization error
- 0817 MCS error
- 0818 ADP initialization failure
- 0820 Machine data file read
- 0821 Spindle gear ratio
- 0822 Wheel data file read
- 0823 AXIS CONSTRUCTION DATA setting error
- 0824 Unit connection mistake
- 0825 AXIS CONSTRUCTION name not set
- 0826 AXIS CONSTRUCTION DATA file read
- 0827 Control axis not found
- 0828 Wire feed axis No. error
- 0833 MCS option program file not sent
- 0834 MCS servo data error
- 0835 MCS communication error
- 0836 Program request illegal
- 0837 Loader spec. code data error
- 0838 Loader backup data file read error
- 0839 Specification conditions failure
- 0840 SuperHi-NC specification mismatch
- 0841 FCP4 board detected error
- 0842 Safety monitor spec. error
- 0845 Specification code setting failure
- 0846 Thermal deviation comp. backup data file read
- 0847 DNC-DT preload task start error
- 0848 PSCB error
- 0849 Synchronous axis tandem control initialization failure
- 0850 MCS Undefined alarm number
- 0851 MCS Inverter unit fault
- 0852 Mistake in data from MCS to NC
- 0853 MCS CON APA deviation
- 0854 MCS Power supply unit error
- 0855 MCS Converter link error
- 0856 MCS DC-bus voltage alarm
- 0857 MCS Motor overcurrent
- 0858 MCS Power unit overheat
- 0859 MCS Power unit overload
- 0860 MCS Supply voltage flutter
- 0861 MCS Inverter capacity differs from spec.
- 0862 MCS Winding change failure
- 0863 MCS Encoder link error
- 0864 MCS Encoder detected error
- 0865 MCS Encoder initialization failure
- 0866 MCS Encoder with shaft detected error
- 0867 MCS Encoder with shaft initialization failure
- 0868 MCS ABSO SCALE error
- 0869 MCS ABSO SCALE initialization failure
- 0870 MCS Magnetic encoder alarm
- 0871 MCS Resolver alarm
- 0872 MCS Pulse generator count over
- 0873 MCS Motor overheat
- 0874 MCS Servo link error
- 0875 MCS Servo link disconnection
- 0876 Mistake in data from NC to MCS
- 0877 MCS Servo data error
- 0878 MCS Illegal command
- 0879 MCS CON speed over
- 0880 MCS Speed command over
- 0881 MCS DIFF over
- 0882 MCS APA speed over
- 0883 MCS Full-closed APA error
- 0884 MCS Over speed
- 0885 MCS Speed deviation over
- 0886 MCS Collision detected
- 0887 MCS Urgent-stop time over
- 0888 MCS Belt is broken
- 0889 MCS Axis change control error
- 0890 MCS Independent encoder initialization failure
- 0891 MCS Calculated current position lies outside range
- 0892 MCS Motor overload
- 0893 MCS Safety speed monitor E-Link error
- 0894 MCS ABSO SCALE sub-slider detected error
- 0895 MCS Tandem control communication error
- 0896 MCS Full abso scale link error
- 0897 MCS Full abso scale error
- 0898 MCS Full abso scale initialization failure
- 0899 MCS Axis stop signal error
- 0940 Time sharing task control
- 0941 Real-time task control
- 0942 Real-time task loop error
- 0943 Main processor name incorrect
- 0944 Slave processor name incorrect
- 0945 Memory board/battery life
- 0951 SMP error
- 0952 Not equipped with processor board
- 0954 Peripheral processor start
- 0955 Spec. code: data file
- 0956 Backup data file read
- 0957 Graphic backup data file read
- 0958 Pitch compensation data file read
- 0965 Configuration file format error
- 0971 Cache data: Initialization error
- 0988 Cache data: Operation error
- 0989 CPU information table data incorrect
- 0990 TASK generate error
- 0991 TASK information table data incorrect
- 0992 PLC backup data file read
- 0993 TCP/IP board illegal
- 0994 TCP/IP configuration file
- 0995 Machine axis data file
- 0996 PLC axis data file
- 0997 PLC monitor backup data file read
- 0998 PLC sequence program load
- 0999 Synchronous tap data file read
