Sinumerik Alarm 10203 Channel %1 NC start without reference point
NC start has been activated in the MDA or AUTOMATIC mode and at least one axis that needs to be referenced has not reached its reference point.
Please inform the authorized personnel/service department. Via the channel-specific MD 20700: REFP_NC_START_LOCK (NC Start without reference point) you can decide whether the axis must be referenced before NC Start or not. The start of referencing can be enabled channel-specific or axis-specific.
• Channel-specific reference point approach: The rising edge of the interface signal “acti- vate referencing” (DB 21 – 28, DBX 1.0) starts an automatic sequence which starts the axes of the channel in the same sequence as specified in the axis-specific MD 34110 REFP_CYCLE_NR (axis sequence channel-specific referencing). 0: The axis does not participate in channel-specific referencing, but it must be referenced for NC Start, -1: The axis does not participate in channel-specific referencing, but it need not be referenced for NC Start, 1- 8: Starting sequence for the channel-specific referencing (simultaneous start at the same no.), 1 – 31: CPU type
• Axis-specific referencing: Press the direction key that corresponds to the approach direction in the axis-specific MD 34010 REFP_CAM_MDIR_IS_MINUS (reference point approach in minus direction).
