Sinumerik Alarm 10209 Channel %1 internal NC stop after block search
Internal alarm which initiates an NC Stop. The alarm is output if $MN_SEARCH_RUN_MODE ==1 and the last action block is activated after block search in the main run. Alarm 10208 is activated depending on the VDI signal PLC -> NCK channel DBB1.6.
– Program execution is aborted, not effective for single axes
NC-Start
