Sinumerik Alarm 10600 Channel %1 block %2 auxiliary function during thread cutting active
An auxiliary function output is programmed in a thread cutting block.
Consequential errors can occur if the machining path of the thread block is too short and further blocks (thread blocks) follow in which no machining stop may occur.Possible remedial measures:
• Program a longer path and/or a lower traversing rate.
• Output auxiliary function in another block (program section).
